Reverse?
RUN will be faster!!
Why would you even consider this? The sled is meant to go forward and fast, not reverse and fast!!
Dont even know why I am even responding to this!
Try gearing up the reverse gears to a 39 tooth, adjust your throttle body synchronization, pull out your magneto rotor... replacing it with a variable frequency drive, increase the size of your cam shaft from 24.4mm to a 36.23mm and last but not least a little duct tape on the kill switch. All of these will make great track horsepower... don't forget to wipe.
da sit backwards you cant go fast unless your looking where youre goin...might help to wear your pants backwards too
Blame it on the Captain and Coke!!!!!
