That's right, interested in a right hand brake lever. Any ideas?
2014 viper, mpi
2009 Phazer 144"
2014 viper, mpi
2009 Phazer 144"
- Apr 14, 2003
- Hessel, Michigan
I always thought of this idea with a brake unit from a crotch rocket. Only question is how would it be incorporated with the existing caliper?
Almost have to have another caliper
HighSpeedLowDrag
A dirt bike master cylinder should fit. I have one here to check.
I will check my bars for room to ad.
2014 viper, mpi
2009 Phazer 144"
2014 viper, mpi
2009 Phazer 144"
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
The throttle is a brake lever when you let go of it...if you listen to anyone that is not used to a Yamaha LOL
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
This shouldn't be a problem. Look into how street bike stunt guys set up their brakes. They have a hand brake as well as a foot brake running the same rear caliper. Not sure how it works but I know someone sells kits to make it work. The same parts should be able to make the hand brakes work together. Just out of curiosity, why?
nherbst454
- Feb 25, 2014
- Woodbury, MN
- 2014 SR Viper XTX-SE
Double up the banjo fittings?
I had a brain stem surgery. My left side of my body lacks feeling. Sometimes miss my brake. It would be safe for myself and others on the trail.This shouldn't be a problem. Look into how street bike stunt guys set up their brakes. They have a hand brake as well as a foot brake running the same rear caliper. Not sure how it works but I know someone sells kits to make it work. The same parts should be able to make the hand brakes work together. Just out of curiosity, why?
2014 viper, mpi
2009 Phazer 144"
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
If that's the case then just get a radial master cylinder front brake set up off of a street bike and eliminate the lever on the left.I had a brain stem surgery. My left side of my body lacks feeling. Sometimes miss my brake. It would be safe for myself and others on the trail.
2014 viper, mpi
2009 Phazer 144"
