dexter
Looking to do "shock treatment" on my warrior. Can't remember if I can dump the whole 12oz into 10 gallons/full tank or if I put less.. Bottle says 1oz per 10 gallon for intermitent use and see dealer for "shock traetment" amount. Advise please
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
use the whole 12oz and burn it out no WOT for long time then when done with that tank change oil & filter and start to use it all time with 1oz per tank.
dexter
What does this do??????
darv
- Aug 9, 2005
- 08 Apex 40th LTX
it helps to keep rings and other things free from carbon and protect some metal parts inside engine I have been using it since 1994 when it came out. we use a lot of it since the dealer i use to work sales 1k of O/B motors and we where having lots of problem becauses of all the troling they do. so that why came out with this product.
dexter
ran a full can and boy oh boy she needed it! she was running real nice after 50 or so miles... sounded crisper and had better throttle response. will drain oil and add fresh stuff... hope it will help with my cold starts. I will use it per tank as it's probably worth it in the long run... sled did not like cold starts and my compression was very low at cold temps so this should do it.
hey vector whats up? it's buster from sledmaine!
darv
- Aug 9, 2005
- 08 Apex 40th LTX
make sure you change oil filter too
- 12K
