crazy canuck
Is there an easy way to open the track windows on the ripsaw (every 3rd is closed)? Do you have to add track clips also? Thanks.
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
A buddy of mine used a rotozip,I saw it and it looked good.He said it cuts pretty fast too.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Are you talking about opening the holes and not clipping them? Maybe extend hyfax wear? Maybe get rid of some of the dreaded 35mph rumble? Hmmm---do you have pictures? Do you think it will compromise the life of the track?
crazy canuck
Steve 05 RX-1 What kind of blade did he use on the Roto-zip?
crazy canuck
Stain...I'm too thrifty (as in cheap) to buy a fully clipped track and want to install extroverts.
Jack_Shaft
Easy job:
(1) Go get double-double.
(2) Buy two chisels at local hardware store (1.5" and 1")
(3) Open up the track and put a workbench or woodhorse "in" it.
(4) Using a piece of 2x4 on its edge directly underneath where you want to punch, use a hammer and the chisels to cut out the holes.
I did not clip the track after punching out the windows and I run Kinetic extros. I have not had any problems. Many mtn. sleds comes that way from the factory now.
I did it to my 05 a couple of years ago and to my daughters 03RX1 this fall. Both times with a roto zip using the standard drywall bit. I took about 45 minutes.
No clips added, no signs of wear to the track and I believe the hyfax life was improved as well as track noise reduced.
suprfst
- Dec 4, 2004
- Tawas Michigan
crazy canuck said:Steve 05 RX-1 What kind of blade did he use on the Roto-zip?
Im not shure which bit he used but he did add clips.I noticed on mine going from the stock closed window track to a fully clipped track it does roll easier most noticably at slow speeds comming up to a corner.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
If I am not mistaken , haven't some mtn. riders been drilling large holes in their tracks to lighten them? This is very interesting if it gets rid of track noise. I wouldn't be running extroverts so guess that it would be no worse than drilling holes for studs???
Try it for a while opend without the extra clips. You will notice the improvement.
PARX
i just used the chisels last night, worked great & clean cuts, better then most of the factory cuts.
ski
- Feb 7, 2006
- Manitoba Canada
- 2015 Yamaha Viper R-TX LE
An exacto knife may do the trick as well... no need to remove the track , just pull the rear flap up out of the way and roll the track cutting as you go...
Jack_Shaft
PARX said:i just used the chisels last night, worked great & clean cuts, better then most of the factory cuts.
I thought the same thing, couldn't even tell which holes I cut vs. factory without really looking at the track and clip placement.
crazy canuck
I'll try out the wood chisel idea...thanks.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
A Stanley knife works great as well. Very sharp and though blade on. Guys laying down vinyl flooring use them for cutting the vinyl. It cuts rubber like butter, I used this knife and some oil to lube the blade, cutting the track was a piece of cake. I have my tracks fully clipped running WhalBros extros on both my sleds.
