Does anyone know how much of a riser you can put on a Nytro short track, without longer cables?
thanks
Leeko
thanks
Leeko
Scooter700
The standard Nytro and the Nytro MTX have the same length cables. The MTX comes with a six inch riser!!
I have 5" fly riser with there bars bolted right on no problems or changes might switch to 7" riser should work fine also
1yamadog
I put a 2.5 inch riser with no problems
devil
if the nytro and mtx use the same cables you can fit 8" fine, thats what i have. i was told for a 10 i would need to start extending lines.
bluechemrider
I put only a 2" and had to reroute but not extend my throttle cable. When I turned hard to the right the engine light would come on and the machine low idles, Luckly this happened when I was riding with my dealer and he told what it was. Thank goodness cause I thought it was a fuel issue
