riser and cables
LeeKo
Chicago
Does anyone know how much of a riser you can put on a Nytro short track, without longer cables?
thanks
Leeko
I have 5" fly riser with there bars bolted right on no problems or changes might switch to 7" riser should work fine also
if the nytro and mtx use the same cables you can fit 8" fine, thats what i have. i was told for a 10 i would need to start extending lines.
I put only a 2" and had to reroute but not extend my throttle cable. When I turned hard to the right the engine light would come on and the machine low idles, Luckly this happened when I was riding with my dealer and he told what it was. Thank goodness cause I thought it was a fuel issue
