Riser Height
sxr70001
Michigan
Sidewinder LTX SE
SR Viper RTX SE
Does anyone know how much bigger riser you can put on without extending cables? I could use a few more inches when I stand up.
I did the same, factory Riser is 5.5" so the 7.5" feels great and cables and wires are fine. I used the cat Riser and it is black and it looks so much better than the raw aluminum look.
7.5" riser Cat part # 5639-884
Thank for the replies.
Do you guys think you could go another inch or is 7.5 pretty tight?
I thought the 7.5 was a nice fit with the cables. Another inch might be ok, but I can't say for sure.
The wires may be fine but the cable might be an issue. Not positive though. The additional 2" makes a huge difference.
Ok, thanks. Do you mind if I ask how tall you are. I'm about 6'1" and was thinking 3 inches would be about perfect. I was just out in the garage with a tape measure, lol.
6' even, maybe you need the extra inch. Lol
I am installing a 7" riser on my wife's sled now and based on what I've seen the 8" I have for mine will work without issue. I should know Thursday for sure. Tomorrow is trail and sign prep for our north end snowmobile trails. Last week was 8 hours so if tomorrow is like last week I won't get to the sled till Thursday.
Nice. Our sign prep is next week. Thanks for donating your time Testmaster.
I am 6'1 with short arms and I use the fly racing 6 inch riser and it works perfect for me.
I have an adjustable riser which ranges 6" to 8.5". Even all the way up to the "ape hanger" position, there's no issue with the cable or brake hose!;)!
Bill
Are u running a ski doo adjustable riser ? If so, did u do anything to make up for difference in width
pjabas,
It is the one from Rox http://roxspeedfx.com/product/rox-6-8in-se-elite-height-adjustable-risers.htm
I marked off couple of different locations on it with a Sharpe and most of the time ride with it in the 7" position. When I have it all the way up, I'm usually off-trail boondocking through the trees. If the trail ride back to the truck is smooth and I'm not standing much, then sometimes I will adjust them all the way down.
Also my mistake in my previous post, I was thinking that they adjusted to 8,5" when in fact it's 8.25".
Bill
