Black 1000
Ok guys I'm going to install the Powermadd pivot riser on my 03. I'm going 2". I have the mountain throttle cable ordered won't be here till Monday. Any tips? I'm sad I can't put it on until I get the throttle cable but thats how it goes. Who's useing this set up and hows it going?
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
You are going to have to drill, and grind down the fillets on the underside of the post plate, in order to get the nuts locked down. OR you could buy metric bolts - use loc-tite. You may not need the Mountain throttle cable as the pivot will bring the cables closer to the tank cover opening.
Finish it off with a Nytro seat.
Yooper_Bob
I recently installed the PowerMadd pivot riser with a 4" block on my '05 Warrior. I love it!
I replaced the stock throttle cable with a mountain cable...only takes 5 minutes and gives plenty of slack.
I had to reroute the brake lines, but everything works with no binding.
Black 1000
Reroute to where?
Yooper_Bob
Black 1000 said:Reroute to where?
I had to disconnect the parking brake cable, and re-route it from the caliper to the handle bar using a more direct route than the factory had it.
Same with the brake line, except I did not have to disconnect it, but just change where the brake line holder was.
The factory layout has a big curve in the routing, and changing that to a more direct (straight line) is enough to fit the riser. :exc:
Black 1000
Awsome thanks for the info. I will do the mentioned next week when I get the new throttle cable.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
I've got a non-pivoting, 2" riser in my 03 LE and I didn't have to change or reroute any cables at all. No problems. I would think if you pivoted it forward slightly you'd gain even more slack for the cables?????
03griz
So on an 03 rx-1 you use the 05 mountain cable? Right?
Black 1000
Any mountain cable form 03-05 I believe will work
03griz
I thought I read the 05 mountain cable is the longest. Or maybe that the 03 mountain cable was not any longer?
Black 1000
Don't know. Ordered mine form VIsion Motorsports in BC and they sent it right out. If you do this mod it's excelent.
03griz
4 inch foam and I think 3 inch riser is what I am leaning towards. I already have some high density foam. Only need the cable and riser.
Black 1000
I got the Powermadd pivot riser. Pivot plus 2" riser equaled 3 1/2". I also had 3" foam added to seat and the upgrades turned out to be very good.
03griz
