canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Broke down and just ordered a OFT relocate kit. Appears most are adimit this is the best mod and constructed kit out there. Thanks to all for the input. Pricey, but maybe this new geometry will help reduce the crappy symptons of the Ortho Arthritis in my shoulders.
Looks like I'll be on a beer free diet for some time..................... naa!
herndonp
Your going to love it. It might feel a little weird at first but, then you will be thinking why didn't I do this along time ago. You better go have a beer and read the instructions several times. The hardest part for me was bending the lower studs you have to get them right so the lower part sits perfectly and it won't bind.
Pete
Pete
pay2play
I love the oft relocate on my XTX. I can't wait to ride this year with the wrp seat I put on this fall. Just sitting on it made it feel so much better. To me, these are two mods that compliment each other well! With uncle Arthur you may like the taller seat for your knees and hips too, plus it takes away the ape hanger affect you get with stock seats and the relocate.
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
I just ordered my OFT kit....like 5 minutes ago, does anyone have pictures of how much they cut, im thinking you are cutting the dash or was your concern the cutting of the cable retainer?. Im not going to cut mine yet but i would like to see it. also any tips on aligning the bars and skis after the install??
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Yea oft-relocator is by far the best mod on a nytro, i want a pivoting riser also but that has to come later this winter.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Nothing is cut what so ever with oft. It's rounded to get furthest forward movement of bars with no cutting needed. That's why I picked the oft. I think the bdx might give little better angle and feel but it looked like bunch of cutting an no going back to stock
canoehead
- Jan 14, 2011
- NE, Alberta
In actuality you need to cut the metal clamp (1" approx.) holding the relocater in place to clear the dash panel and also the rubber cable fairlead. Not a big deal. I used my powermadd riser with this and WOW what a differance. I got ape hangers on my sled to. LOLNothing is cut what so ever with oft. It's rounded to get furthest forward movement of bars with no cutting needed. That's why I picked the oft. I think the bdx might give little better angle and feel but it looked like bunch of cutting an no going back to stock
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Oh. Well suppose everyone does it diff. I cut nothing for my oft.
Edit: oh you mean the "mounting bolts" I just bought new bolts
Tommyboy
Did you have issues with increased RPM when turning the handle bar, they warn you about this but don't tell you how to correct other than refer to owners manual. Cheers and happy new year!Yea oft-relocator is by far the best mod on a nytro, i want a pivoting riser also but that has to come later this winter.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
No problem on mine...just had to re-route the throttle cable as per instructions...
yamahamm
- Oct 9, 2009
- Norway
No problem on mine, i just rerouted per instructions and all works greatDid you have issues with increased RPM when turning the handle bar, they warn you about this but don't tell you how to correct other than refer to owners manual. Cheers and happy new year!
Tommyboy
ThanksNo problem on mine, i just rerouted per instructions and all works great![]()
DeepFrz
I've ridden 3 full seasons on my Nytro with a Lake Effect Pivot Riser (great product btw). This past weekend I put on an OFT Relocater as well as the riser and got to test it out in the trees. It's a big difference! The sled is much easier to steer and much easier to handle when boondocking with the relocate kit. You will not be disappointed!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I was looking at The CR re locator and is it the bracket which is only $25? How does it work?i have the cr racing one. cheaper and use stock bushing but it's from canada!
it's my third winter with it and never had any problem.
johnelway
yes it's that bracket.I was looking at The CR re locator and is it the bracket which is only $25? How does it work?
It only raise the steering bushing that the steering column is more vertical.
very easy to install.
