Riser????
Black 1000
Beaverton
Who sells a great 2" riser for an 03 RX1? Who's useing one and how does it compare to stock? :rocks:
Royal Distributing has them.
They work great (once your shear the pin on the bars, and move throttle in so TORS doesn;t come on).
The only complaint is the way my canvas cover fits (or doesn't) over the bars and hand guards.
Once you put them on, you wouldn't remove them.
Shear the pin? Is that the locating pin? Just grind it off right? What kind of cover do you have? I think theres room in mine.
Grind off or snap it when you articulate the bars forward (if I remember correctly).
I've got a canvas cover. Bitch to get on now. With the low windshield and the raised bars it sure doesn't look or fit very well now.
Stock Yamaha cover? Mines an aftermarket cover form a company in the states. It should fit.
Thanks though I will look at Royal ;)!
RXWON said:
Powermadd makes a good riser also.
I absolutely love my Powermadd pivot riser with Mountain cables. 3.25" high. Not sure, but it may also work with stock shorty cables.
I have a Rox..not sure if they make a 2".
Also, I have no issue with my cover...short windshield, 3.5 riser lift, and Handguards. No issues with the Yami stock cover with the stretch windshield panel. Its tight but works.
Ok I'm going to get a 2". No problem with stock cables? Shouldnt be its just 2"
ROX does make a 2" riser. I have it on but havent tried it yet. NO SNOW It seems ok when I turn the bars, no isues yet.
I have a 2" riser. 1000 miles and no new cables, no new problems. Works perfect. Stuff your seat with about 3-4 inches of padding and you will have one of the most comfy sleds out there!!!
I also have a Rox 2" pivoting riser,stock cables(must remove the cable guide from the upper handle bar clamp) 2.5" added seat foam and RS Venture windshield on my 2004 Warrior, works perfect
I have the 3 1/2" rox riser and love it. I also have the seat mod done and it is pimp as well. Did have to get the '05 mountain throttle cable, but was only $21.
Aaron
I have my seat stuffed with 3" of high density foam. Not bad. I like the Powermadd 2" riser. What does the pivot do? Obviously pivot but what are the advantages?
