HABS 1
 - Oct 22, 2015
 - corunna,ontario
mine will hit 10.800- 10900 and stay there, with u still getting speed mabe yr tach out?
		srxr700
 - Feb 8, 2012
 - cedar springs michigan
 - 2006 Attack
2012 Vector
Funny you say that. I had a guy message me when i was having my backfire issue. Said his buddy had the same issue and it was a bad speedo cluster...Could be. Or a plugged filter in the tank possibly?
		srxr700
 - Feb 8, 2012
 - 2006 Attack
2012 Vector
Thanks everyone for the help. I just wanted to follow up on this thread in case future owners experience what I went through.  My problem all along was a bad fuel pump!!
			yama_rider
 - Sep 15, 2014
 - New Brunswick
 - 2009 RS Venture
How did you diagnose this?
		srxr700
 - Feb 8, 2012
 - 2006 Attack
2012 Vector
Rebuilt both clutches, inspected drive train, two new sets of plugs, tested coils, fixed all ground blocks, dialectic greased all connections, new battery, new air box, tested tps, new 87 octane, checked alignment, new header gasket, new muffler, new copper donuts, new y pipes......
Almost gave up, but pulled the plugs again after hard runs and noticed the plugs were white...didn't test the pump, I just knew it was the problem. 500 dollars later and I'm in heaven.
The brp wheels and 5.7 pilots are amazing as well. Hit 127 on the dream o meter on hard pack today.
upnumber6
 - Jan 3, 2016
 - Winnipeg
 - 2007 apex rtx, 2011 apex se
anybody know what kind of psi that pump should be putting out?Rebuilt both clutches, inspected drive train, two new sets of plugs, tested coils, fixed all ground blocks, dialectic greased all connections, new battery, new air box, tested tps, new 87 octane, checked alignment, new header gasket, new muffler, new copper donuts, new y pipes......
 - 7K
