wolfe9904
- Dec 29, 2013
Looking to put a rsi riser on the 07 phazer . Just wondering if there is any kind of relocation bracket to use . Or what guys are doing ? Thanks
Gone Blue
- Oct 11, 2006
- Howell, Michigan
If you use this style of Rox riser you don't have to relocate the gauge pod. I put on a 2" on my friends Phazer and you can hardly see it on the sled.
http://roxspeedfx.com/product/2in-rise- ... risers.htm
G.B.
G.B.
wolfe9904
- Dec 29, 2013
Not so much a height thing . Was looking to put a little better looking riser on
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Many people (like I) do mount the pod on top of the light cover.
I like it that way, because the original mount I think is a bit in the way for the view.
wolfe9904
- Dec 29, 2013
What's the best way to bolt it on that way ?
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
wolfe9904 said:What's the best way to bolt it on that way ?
I just drilled 3 holes for the mounting screws and made a hole for the cable to connect to the pod. Nothing fancy, but it looks good.
weldion said:wolfe9904 said:What's the best way to bolt it on that way ?
I did mine the same way, works good. I used the rubber grommets from the original bracket..
