jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I have tried doing some research on fox web site but they give a wide range of air pressures for the evol rc2 and nothing by weight. I believe now I am running the main at 75 and evol at 150 the center shock I have increased the preload and 4 clicks on compression and I think I may need some more because i get some bottoming on the from of the rear skid on larger bumps the rear springs are one at hardest and the other in the middle with the rear shock increased by 2 clicks with the rear coupler blocks removed. I am 240lb, is there anyone else with the RR suspension around my weight that has it dialed in?
Jeff
Jeff
