slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
I was told long time ago never to run engine and rev it without a belt on it. Ive herd of people doing this and would like others ideas about that. I'm sure the list of why not to do this is longer than the list of to do this.
RobX-1
- Coldwater, OH
IMO, it's not an issue if you ease into the throttle per se; it's when you whack the throttle and then cause the primary moveable sheave to smack into the fixed sheave since there is no belt to prevent this from doing so is when it's not a good thing. If I ever do do this, I'm always conscientious of keeping the RPMs low enough so as to not even engage/move the primary sheave.
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Is it possible to over rev engine without belt on causing engine and or clutch damage
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I'm curious why you're asking about running with the belt off?
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
There was a posted video on here that sparked a conversation with another user. They had posted video running sled with belt off. I sent a nice pm to them not sure if be doing that. They asked why. That's where I'm at because I was told not to and I don't do this. The engine was revved up a few times in video although it didn't seem like the revs were higher.I'm curious why you're asking about running with the belt off?
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Copy, personally I don't run it with the belt off but in the rare case I do, it's only at idle or minor revs not to the point of clutch engagement. I agree high revs the clutch will slam together and there's high potential of it exploding catastrophically.There was a posted video on here that sparked a conversation with another user. They had posted video running sled with belt off. I sent a nice pm to them not sure if be doing that. They asked why. That's where I'm at because I was told not to and I don't do this. The engine was revved up a few times in video although it didn't seem like the revs were higher.
