rednecksized
just picked up an 04 rx warrior with a thrown rod. I am putting the reverse on my 03 rx1 and was wondering if i need to change the jack shaft. i see the warrior shaft has an o ring on the shaft and my rx1 doesnt. am i really going to loose oil out the top shaft if i dont? Thanks.
rednecksized
Got it figured out. Just had to use the outside set collar from the non-reverse outer case. It has a sealing oring to take place of the one on the jack shaft. Thanks.
good to see you figured it out.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
There are step by step instructions for this in the tech section, used them when I did mine.
