bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
i have an RX Warrior that has run flawless until this year. The carbs were leaking fuel; so, I disassembled them, cleaned them synced the butterfly’s and put them back on the sled. The sled started and idled fine; but had the fuel gauge and indicator along with the warning light came on. Light flashed 8 times then waits a couple of seconds and does this cycle again. The fuel tank is about half full. The other problem I am having is that when you give the motor gas, it seems to be missing and when I took the sled out in the snow it had no power when accelerating. It would stumble and gradually increase in rpm. Does anyone know what my problems are? Thanks.
