happy1426
will apex gears fit in the rx1 are they the same and use the same chain?? thanks!!
SHodas
Which rx1, an 05 will, not sure about 03 and 04
Sled Dog
I am not positive but I think they are the same and interchangable maybe check out the part numbers to see if they are the same.
happy1426
Ya mine is a 03 I want a switch the gears while I take of the chain case to replace the seals!!
Sled Dog
What do you have now and what are you looking to do gear up or down. Keep in mind you most likely are going to have to clutch to get the most out of the gear change. You can click on the links in my sig to get a gear to speed calculator.
grader
they are all the same ( rx1/apex).
happy1426
i want a go 22/40 that is what a buddy of mine said he has, and yes im buying a clutch kit too!
Sled Dog
I am currently running a 24/40 set up on my mountain I took it out last night and its running great still pulls hard with more top end. What kind of track are you running?
