PAYNER67
I have a 2005 RX1 in need of a track and have found a nice one off a 09 Attack - will it fit ? both are the same size just not sure about pitch and dont know how to measure for it
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yep it will fit. Although if I were doing a track change the last thing that I would put on it would be the rip saw. Look into a cobra or carve unless your getting it dirt cheap.
grader
rx1 121inch track, attak has a 136 inch track. will need extensions to work.
grader said:rx1 121inch track, attak has a 136 inch track. will need extensions to work.
Other then that length, it will be just fine on the RX1 with a 136 ext. I have had great luck with the Rip Saw. Cobra is to soft for me and ripped apart.
kinger
- Jan 17, 2005
- Clear Lake, IA
I wouldn't be quick to generalize with a sample of 1. On my 250 hp sled the cobra looks new after almost 2500 miles and I am not easy on it as the spin is hard to control on pavement, etc.
Where as I have personally seen 6 ripsaws shred in front my eyes in less then 3000 miles on mostly stock sleds.
Thought he said length was the same in his orginal post?? I assumed he had a warrior and just left off the warrior or something.
kinger said:I wouldn't be quick to generalize with a sample of 1. On my 250 hp sled the cobra looks new after almost 2500 miles and I am not easy on it as the spin is hard to control on pavement, etc.
Difference of opinions... my 230 hp sled ripped that cobra track apart in less then 1000 miles and the I have had several ripsaw tracks on lower HP sleds with zero problems. To each his own ... to many factors for the difference of opinions.
Ill tell you this, I wont spend $600 plus dollars on the Cobra track to get burned again... 1 bad track is still a bad track. I also stud my tracks and maybe that's the weakness.
