rx1 carb cleaning
I will leave the orings off then , I do see where cleaning the pilot jets are a pain to clean..I run a copper wire through them and spray out with carb cleaner then when I blow air through them it packs more crub in the opening, looks like I need to just keep cleaning till no more junk collects in it.
Thanks again
Get some Mechanic in a bottle and run around 4 oz through a tank of gas. Enjoy your ride and ride safe.
New question/issue
I ordered a rear guide wheel off ebay..the one I received is the type that the bearing can be replaced pn 8cr-47550-00-2 the one in the skid has the type that the bearing cannot be replaced in..any idea what bearing I need for the new wheel? Will I need the plastic bushing for the bearing as well?
Thanks!
You need to fill in your location its a site requirement. I am not sure of the bearing but someone will know and chime in. We are a very helpful bunch here. :mod:
