69camaro
- Sep 22, 2014
- Oakfield, WI
- 2005 Rx1
I have an 05 rx1 with a CPR turbo, drag sled only. It has an MC4 ignition with MSD boost controller. The problem I am having is that the stutter only works well when the sled is cold. By cold I mean first pass of the day with the sled having been warmed up to about 180 and cooled back off to about 120. The stutter will work perfect every time the first pass. Will build 10 lbs of boost in about 2 seconds at 4800 rpm. Make a pass, cool sled off, line it up again, stutter will not pop hard at all. Maybe 1 or 2 pops and thats it, its just limiting rpm. It almost acts like its not pulling the timing out, but after checking the laptop the datalog is saying timing was pulled. Will only build 1 or 2 lbs of boost. Anybody ever encounter this problem before? I have heard its possible that it may be jetted to rich? It does seem to work better in winter, although I did have the same problem a few times last winter. Im running 152.5 main jets and 15 pilots. I pulled the carbs off and they were spotless, still cleaned the carbs thoroughly and it made no difference. Im running out of ideas...
