RX1 electrical wont start
kuku
central IL
Just went to start my RX1 and it turns over fine but does not fire. I parked it a couple of weeks ago and I was going to let it warm up to check the oil ( I added oil thinking it was low and thought I would let it warm up then check it to see if I didnt add too much) anyway it would not fire. I went ahead and changed the plugs and then took air box off and squirted some starting fluid in the carbs and it would not even fire on that, so I am thinking it is electrical. Is there a fuse that could of blown or do you have any ideas??????
shake the wires around starter relay while holding the key on. These sleds loose the ground some times. If it works, then you need to run a new ground wire from the relay to the frame.
