Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Did you replace rod bolts , is it a supercharged or turbo engine just wondering if rebuilding engine if rod bolts should be changedCon-rod caps can now go on. 1st torque is 14 ft/lbs, second is 14 ft/lbs + 120 degrees. 1st pic shows where the Yamabond has to go.
quadsean1
The Yamaha manual says to always replace rod bolts upon being torque so I would especially in a supercharger or turbo application replace the bolts with stock rods.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks guess I am ordering rod bolts
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
is this the same for the apex? the mark is the double one not the single mark after that one?Cylinders 1 & 4 at TDC.
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
RX and Apex are the same.is this the same for the apex? the mark is the double one not the single mark after that one?
The timing mark looks something like this:
I--------I I
You want the pointer lined up with the last "I" on the right hand side above.
