MIDWAY
- Feb 12, 2008
- SE, MN
- 2015 Yamaha Viper LTX SE with Push Turbo
Well it is definitely better but I think I might have to shim them actually a little bit more. I think I am at around 3/4" shimmed. And it seems that my right ski might have to be shimmed more than my left??? I do have 7000 miles on and maybe those rubber pieces did not wear evenly???
Indy
MIDWAY said:I have shimmed mine and it helped but it still darts badly. I tried to take preload off my front shocks but it is way to soft in the corners and is tippy. I don't see how you guys can ride with almost no preload, am I doing something wrong? Also can someone explain to me how to set my toe out 1/8"??? Thanks
what size is your swaybar? that is probably why your front end feels soft. Have you canged the links?
MIDWAY
- Feb 12, 2008
- SE, MN
I did the links, bar, and front springs quite awhile ago.
Indy
with the larger swaybar, i am surprised that you think the the front end would feel soft with preload off of shocks. i've done it all, including wide front end kit. i even have my ohlins turned all the way soft. i guess all sleds are different. i dont have anything else to suggest. good luck.
