chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
2 seasons on mine with 3" Hyperflow, CAI, Turbosmart BOV, and tune bundle almost always set at 270. Lots of WOT pulls, lake running and 60-80mph trail cruising. Never had any issues - exhaust and tune play very well together.
Thanks for the feedback. I have a few questions if you don't mind.
Did Hurricane set you up with a special tune for CAI?
Do you have the knock protection update on your tunes? Any detection's?
Are you running 91 octane or higher?
Are you running the stock bar sensor?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
No, Dave didn't make a special tune specifically for the CAI. I was with Mike at Sandale last year when the pulls were being done on Daves 270-290 tunes & 3" Hyperflow. I don't remember the exact number, but we were seeing more that 270 (closer to 290 I think) and a bit leaner up top than you'd want. Mike did a bunch of pulls over the next couple days and was sharing those logs with Dave, who ultimately tweaked the bundle to make the most of tune/exhaust combo. The tunes that resulted from this were made available to all a few days later, and are what I ran all of last year.
Yes, I run knock protection (all Hurricane tunes do) and have seen some knock events in my logs. Typically, .5 degree of timing is pulled. I run tall gearing, and 192 1.63" nails. I've only seen this when doing back-back drag starts where there is significant load on the engine.
91 always with 270, and will add a gallon of 110 when playing with 290.
Stock right now, will be installing a 3 bar before riding season starts.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
How much boost does the 290 tune make?
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
About 17lbs
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
About 17lbs
Very similar to the 270 map, Just more timing.
Dan
