ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Thanks for reply Mike!Dan,
This is pertaining to the 3inch exhaust with the Hurricane tunes. We tested the 270T tune with our HeartBreaker and let's just say it makes a pile more hp then 270... so it is up to the end user but I would suggest an update.
You will be fine with the modded muffler.
Mike
I have been saying this since my 3" cat Sandale muffler, noone makes more power or a nicer muffler then Sandale! Great work sir!
Dan
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Correct.So just to clarify, by adding the Turbosmart BOV, this will NOT cause overboost more than the intended PSI for the respective tune. Is that correct?
The issue (as Mike mentions above) is that the stock bypass valve was opening below target boost pressure. Installing the Turbosmart corrected this, and let him dyno the tune as written by Dave.
There was no over-boost.
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Providing the tuners are using the Turbosmart BOV's when building their maps then there should no reason for any over boost.So just to clarify, by adding the Turbosmart BOV, this will NOT cause overboost more than the intended PSI for the respective tune. Is that correct?
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Thanks Jim!Correct.
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Thanks Dan,Thanks for reply Mike!
Dan
Appreciate the praise, we thrive on putting out the best quality period!
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
See ya friday for the update/bov robbie!
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Here is some data for you guys on the "new" 270R tune.
Running our 3inch HyperFlow, -30 outside a/f was 11.4 at WOT, boost was at 16.5psi @9000 rpm. The tune is so violent that traction is definitely an issue, stabbing the throttle at 40mph is pointless with 196 studs. Cruising speeds a/f was in the 12.8- 13.2 range which is more then safe with no load on the motor.
Dave has hit a home run here, after speaking with him last night it sounds like he's working on some interesting stuff!!!! (stay tuned)
Mike
Mike
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Love it! Knapps description using the word violent has become the one word to sum up a Hurricane tune! What a season this is gonna be!Here is some data for you guys on the "new" 270R tune.
Mike
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Not sure how else to describe it, first thought that comes to mind.Love it! Knapps description using the word violent has become the one word to sum up a Hurricane tune! What a season this is gonna be!
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Sorry should have mentioned we were holding it for 3000+ feet...
TT
It was to our surprise this year that we have seen lean conditions from the combination of hurricane tunes and the sandale 3” mufflers. We all know that efficiency causes this and I’ve been impressed by the flow of this muffler. Through conversations with mike at sandale,we desided to work together to deal with this lean condition.this turned out to be an awesome experience working with mike.
Over a couple of days on his dyno,we have updated flashes for the 3in sandale mufflers in trail testing this weekend.
It is the policy it hurricane Performance to offer free updates for reasons just like this.anyone with the hurricane flashes are welcome to the specific hurricane 240,270 &280 race flashes for the sandale 3” mufflers at no charge. Just simply contact us or your hurricane dealer and arrangements will me made
David or Sandale,
Maybe it is my bad english skills, but is there specific race tunes to Sandale 3» exhausts? Or were alle the normal race tunes updated to be able tonuse with any after marked exhausts incl Sandales 3» exhausts options? Nice to know when Sandale is have a 10% sale
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
All the Hurricane performance muffler flashes are designed to be able to use the sandale 3” mufflers
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Hi TT,David or Sandale,
All Hurricane tunes now compliment the SanDale 3inch exhaust systems. There was an update done last winter.
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Lol, beat me to itAll the Hurricane performance muffler flashes are designed to be able to use the sandale 3” mufflers
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
When you say 3" exhaust systems, you mean both the Hyperflow and Heartbreaker?
Are the tunes setup for a CAI as well with the 3" Sandale Systems?
Are both the Hyperflow and Heartbreaker available from Hurricane Performance?
