J-fuzzy
- Feb 28, 2019
- Upper Michigan
- 2014 SR Viper LTX
- Escanaba
I’m tore between the two clutch kits. I have a 14 LTX viper. Bikeman can, 144 studs up the middle, air box mod and the ECU is on its way back from EVO 2.5. My last bit is what clutch it. I want low and mid range. Could care less about the top end. I’m not sure if they are a horse a piece or if one is truly better than the other?
I use sponsors. So Thunder, Ulmer or Dalton would be my choices.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Thunder Products hands down, awesome low and midrange, pulls like a freight train and more top end too.I’m tore between the two clutch kits. I have a 14 LTX viper. Bikeman can, 144 studs up the middle, air box mod and the ECU is on its way back from EVO 2.5. My last bit is what clutch it. I want low and mid range. Could care less about the top end. I’m not sure if they are a horse a piece or if one is truly better than the other?
rbell14
I'm happy with my TP clutch kit. Service was excellent and they had my weights dialed in on first try. That said, I'm sure Schmidt Bros. makes a nice kit also, I just don't have any experience with it.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Support our site sponsors and vendors guy's, they contribute a lot of wealth of knowledge to this site.
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
I have the big venom kit.midrange is awesome over stock.don't think top end is any better.the service from thunder is outstanding.
Kenzie
- Feb 27, 2015
- Viper ltx se 137 turbo
Hard to beat Tim and terry service from thunder products.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Big Thunder, my sled didn't have the slow top end problem from the factory so not much help there but the Idle-upper midrange performance is awesome with the kit. I've run the kit with 8jp, gates carbon 8jp, and 8dn and it works good with all those belts.
09nytro
Can’t go wrong with thunder, ulmer or dalton all are great upgrades .... Schmidt Bros uses stock fly weights and are a pain to adjust plus you can’t fine tune them as well ... just my .02
