I have a 2018 STX-DX 146 sidewinder that started giving me a SD-12 code with the 5500 RPM. The sled does have 18,000 miles but has all preventive work done. I replaced the battery as a first step and the unit did start fine for 15 time over two days but when I was loading it on the trailer it would only crank over but not fire and the generate the SD-12 code. Should I replace the crank position senor by itself or do both the stator and the sensor. The OEM stator is $400 so I would like to avoid that. Is it best to test the stator with the engine running instead of the OHM test?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Here is some reading for you.I have a 2018 STX-DX 146 sidewinder that started giving me a SD-12 code with the 5500 RPM. The sled does have 18,000 miles but has all preventive work done. I replaced the battery as a first step and the unit did start fine for 15 time over two days but when I was loading it on the trailer it would only crank over but not fire and the generate the SD-12 code. Should I replace the crank position senor by itself or do both the stator and the sensor. The OEM stator is $400 so I would like to avoid that. Is it best to test the stator with the engine running instead of the OHM test?
SD12. Dead
Got up this am tried to start 17 winder. Cranks over won’t run. SD12 code. Tried all connections and still same. Anyone replace crank sensor or have this code? thanks
Also if its the crank sensor you will not get it running at all. If its truly a failure(ohms test) will tell you. Don't need to be running. Its been awhile since I changed it but pretty certain you can just replace the sensor not the whole stator and sensor. With those miles I would do the whole thing.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE
18 Winder LTX 50th
97 SX Vmax 600 (red)
I feel your pain, just went through this a couple of weeks back. Start of a week-long trip, go start it to get it off the trailer and no go, the dreaded sd-12 code. I found a dealer that had the stator so just had them install it as I didn't have all the tools required to do the job with me on this trip.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE
18 Winder LTX 50th
Jon as I understand it, it can be done but not an easy task. I hear it's pretty complicated replacing just the sensor.Its been awhile since I changed it but pretty certain you can just replace the sensor not the whole stator and sensor.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
It can be done as I understand it. BUT that would be done by someone with electrical knowledge. That's not me so much beyond basics. The price is way more now then when I did it. We did the whole works. With the miles on the sled of nov7829 I think its a no brainer just to do both.Jon as I understand it, it can be done but not an easy task. I hear it's pretty complicated replacing just the sensor.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
How many miles was your failure at? Just curiousI feel your pain, just went through this a couple of weeks back. Start of a week-long trip, go start it to get it off the trailer and no go, the dreaded sd-12 code. I found a dealer that had the stator so just had them install it as I didn't have all the tools required to do the job with me on this trip.
