Sd-14 code 17 sidewinder
Cspittle
Age
32
aroostook County
2014 Yamaha viper turbo
hello everyone so I just picked up a low mile sidewinder only has 900 miles on it love the sled. Took it for its first ride yesterday run great till I shut it off after restarting it I had a code sd-14 and the sled would idle but not move. The sled does have a upgraded intake that still sits under the hood also a 270 flash from turbo dynamics 3 bar map sensor and the updated waste gate just wondering if anyone has experienced this? Or what would cause this.
could the tune cause this?
IMO, doubtful. Not sure what you mean by "upgraded intake."
My guesses without seeing sled: intake leaks - loose clamps, split or loose hose, loose intake boots, loose boost tubes or vacuum leaks at control points, loose "upgraded intake", cracked plenum, bad connection to sensor, broken wire to sensor, or still possible sensor failed.
All just guesses without seeing sled.
Always excellent info brother......great work.
Dan
Thanks for the reply’s I did figure this issue out. The previous owner left the flasher plugged into the machine all the time I unplugged the flasher and it hasn’t given me any trouble since I’m unsure why it would cause this code but it definitely was the issue.
