Cspittle
- Jan 28, 2019
- aroostook County
- 2014 Yamaha viper turbo
hello everyone so I just picked up a low mile sidewinder only has 900 miles on it love the sled. Took it for its first ride yesterday run great till I shut it off after restarting it I had a code sd-14 and the sled would idle but not move. The sled does have a upgraded intake that still sits under the hood also a 270 flash from turbo dynamics 3 bar map sensor and the updated waste gate just wondering if anyone has experienced this? Or what would cause this.
Cspittle
- Jan 28, 2019
- aroostook County
could the tune cause this?
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Check all intake and tubes from intercooler for loosened clamps before anything else.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, doubtful. Not sure what you mean by "upgraded intake."could the tune cause this?
My guesses without seeing sled: intake leaks - loose clamps, split or loose hose, loose intake boots, loose boost tubes or vacuum leaks at control points, loose "upgraded intake", cracked plenum, bad connection to sensor, broken wire to sensor, or still possible sensor failed.
All just guesses without seeing sled.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Always excellent info brother......great work.IMO, doubtful. Not sure what you mean by "upgraded intake."
Dan
Cspittle
- Jan 28, 2019
- aroostook County
Thanks for the reply’s I did figure this issue out. The previous owner left the flasher plugged into the machine all the time I unplugged the flasher and it hasn’t given me any trouble since I’m unsure why it would cause this code but it definitely was the issue.
