WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
During a ride I had SD-26 pop up on my gauge, did 215km back to truck and code never went away, till today as soon as I turn the key to the on position the code pops up.
Had a forum member NO1B4ME do a leak down test and looked over everything and all seems to be good, Yamamarc has sent me his personal flasher but it’s stuck up somewhere in the shipping process
Big tanks to NO1B4ME, Yamamarc and hellflyer for there help with this issue.
Sled runs good even though code is always there. I have the 240ss tune. We switched the 3 bar map sensor with another one and still same thing happens with code always flashing. I’m itching to ride but don’t want to take the chance not knowing if sled is running lean or not.
Any thoughts to this code ??
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Are you venting the oil tank to atmosphere? If not, hose are clog whit #*$&@....:-/
Clean everything, oil tank to atmosphere or rov bybass and i bet problems solved...
WinderFab
- Mar 1, 2009
- Woodbridge, ON
My first ride on my new to me 2020 sidewinder was in Temicaming Quebec, after the first day I noticed a bit of oily water in my air box.. after that ride I took out the oil line going into the air box and made it vent to atmosphere..
My lines are all clean..
Pstn head
Not sure on the 2020's but the 2017 that code says "upstream pressure sensor"
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes same with the 2020’sNot sure on the 2020's but the 2017 that code says "upstream pressure sensor"
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Had a forum member NO1B4M do a leak down test and looked over everything and all seems to be good, Yamamarc has sent me he’s flasher but it’s stuck up somewhere in the shipping process..
Big tanks to NO1B4M, Yamamarc and hellflyer for there help with this issue.
Pretty disappointing I shipped it 2 day priority last Monday!!!!
And now you can't ride this weekend!!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
That's sucks! Good old canada Post delaysPretty disappointing I shipped it 2 day priority last Monday!!!!
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Don’t stay home for that code, ride that thing! Make it boost hard couples miles. Code will went away . Sd26 is usually moisture in sensor that froze. If you ride it at low speed in vaccum it is worst for this code.
you have enough protection in your ecu to not stay home!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Well Byam I took it out today and code still flashing.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
GrrrrWell Byam I took it out today and code still flashing.
sled run well? I think you are gonna be able to erase it with the flasher!
code is always blinking?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes sled runs normal..Yes the code is always on, even just with the gauge on the code is there flashing.. I’m patiently waiting for the flasher to show up..
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hopefully it show up today if not maybe we can find someone will to help in Southern Ontario with flasher to help you out!!Yes sled runs normal..Yes the code is always on, even just with the gauge on the code is there flashing.. I’m patiently waiting for the flasher to show up..
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Just got back from a 1,400+ mile trip in Maine. Mine was flashing sd-26 all week. When I shut the sled off at trail breaks code gone, when I rode to close to my buddy leading in his snow dust, code back or put my thumb in it code back. Stopped at a Cat dealer about the code. He told me don't worry about it, ride it. Other then sd-26 and my heated seat not working after Wednesday sled ran like a champ.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
In my case since the second the code popped up it hasn’t gone away..Just got back from a 1,400+ mile trip in Maine. Mine was flashing sd-26 all week. When I shut the sled off at trail breaks code gone, when I rode to close to my buddy leading in his snow dust, code back or put my thumb in it code back. Stopped at a Cat dealer about the code. He told me don't worry about it, ride it. Other then sd-26 and my heated seat not working after Wednesday sled ran like a champ.
Also I was leading for the hole ride so it can’t be snow dust..
Did the cat dealer give you any reasoning to why he would say just ride it.
I’ve been told by two tuners not to run the sled until I delete the code.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
If you hold full trottle over 5 sec that code will go away.In my case since the second the code popped up it hasn’t gone away..
