eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Just checked the freeplay on my XTX and there was NONE... There is supposed to be 1-2 mm so I removed a shim. The offset is supposed to be 13.5-16.5mm and was at about 16mm. By removing the shime behind the secondary I was able to reduce the offset to 15mm and get 1 mm freeplay. My question is the manual that I am refering to is from the 2008 Nytro and not a 2009. Are these measurments the same for the 09 xtx? Thanks
