09nytro
I think it's the same jack shaft as the apex and vector as well as the splines...I e-mailed Jason @ team to find out .....
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I think that's the same as a nytro.
The Apex/RX/Vector ect. Is the same as the phazer. I believe the phazer is 25mm. I can take a measurement in the morning.
09nytro
I can check my old shaft out of my nytro ....
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
To put a team secondary on a nytro you had to change the shaft and then bolt on the secondary. If the viper has a cat shaft on it and the Yamaha clutch has new splines the team roller will just slip on with the shaft
09nytro
So what you are saying is that are team secondary's are yamaha splines ....
yukon yamaha
- Jan 30, 2008
no you have to change the jack shaft to make a team roller fit a yamaha nytro
09nytro
Yes I know that I have the kit in my sled....just wanted to find out if my clutch will fit the viper.....
yukon yamaha
- Jan 30, 2008
09nytro I really hope so! I want to change mine over too!!!
but like I mentioned before the jack shaft is a cat part with cat gears on the one end and a yamaha clutch on the other end
Two options
Yamaha changed the spline on their clutch to work with a cat jack shaft
or
the jack shaft is new and cat gears on one side and the shaft is splined for yamaha clutchs
I hope it is a cat spline beacuse team sells the team for 250$ without a helix. But if the nytro one just slid right one i would do back flips!!!!!
Two options
or
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
i thought that team tied is straight bolt on on apex?
iasledder
Anyone concerned with having the drive belt above the brake line?
09nytro
Not really......
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Nope
09nytro said:I can check my old shaft out of my nytro ....
Did you ever check the Dia. of the Nytro shaft?
09nytro
No...and it's all apart right now getting it ready for summer so I will tomorrow ....kinda forgot.....lol.....
Thanks! Stalling on my Phazer overhaul since tempted to drive north for one last ride.
