To put a team secondary on a nytro you had to change the shaft and then bolt on the secondary. If the viper has a cat shaft on it and the Yamaha clutch has new splines the team roller will just slip on with the shaft
09nytro I really hope so! I want to change mine over too!!!
but like I mentioned before the jack shaft is a cat part with cat gears on the one end and a yamaha clutch on the other end
Two options
Yamaha changed the spline on their clutch to work with a cat jack shaft
or
the jack shaft is new and cat gears on one side and the shaft is splined for yamaha clutchs
I hope it is a cat spline beacuse team sells the team for 250$ without a helix. But if the nytro one just slid right one i would do back flips!!!!!
