JERSEYJOE
Came to a quick stop today as I nearly missed a road. when I tried to start the belt slipped. Took the cover off and the secondary clutch was not back to neutral.. Had to manually roll the belt and coach the clutch closed. Was fine all day after that. Is the spring too weak or ??????
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Had the same problem this winter. Anyone have an answer.
I had it happen once. Never happened again. Think the belt gets wedge in secondary if the belt has some miles in it. How many miles on it? I would not worry about it unless it happens again.
henseljg2
Same happened to me. No explanation but wasn't an issue after that.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
what they said. had a friend with his 08 apex do that but it was after he had placed it in reverse. he backed up to quickly and then went forward. thought that he had broken his chain case because it w as making a horrible noise. checked and the belt got sucked into the secondary.I think it gets sucked in because it happened so suddenly that the secondary didn't have time to react. don't think you have anything to worry about
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
This is normal and will happen any time you come to a (brake locked up...sliding stop).
When at speed the belt is riding partially down in the secondary instead of at the top. If while at speed (belt lower in the secondary) you suddenly lock up the brakes the secondary stops rotating and locks the belt in the lower position. When you go to start rolling again it will be like trying to start driving in 3rd gear instead of first.
To prevent this from happening: if you can, after locking up the track to stop, release the brake and allow the track to rotate for the last few feet just prior to coming to the full stop. This short rotation at the tail end of the stop will bring the belt back up to the top (first gear) of the secondary. Problem solved!
HTH
HTH
JERSEYJOE
Makes sense but I have had this sled since new in 2006 and it never did it before this year. Has a new belt. I frequently do a slide turn at the end of a road and it never happened. Also my SRX and Viper do not do this ever. I was thinking a good cleaning and a little more tension? also the secondary spring is the original one with over 10,000 miles on it.
Right clean and drop in a new spring... I agree with that considering the miles.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
Ah, more information.
Given the miles I agree with Mr sled's recommendation. You are due for refreshing.
I have experienced what I described earlier in all of my Yamaha's from new: 07 Attak, 07 Phazer and 11 Apex. It happens EVERY time the track is locked up all the way to a complete stop from any speed above 20 mph.
JERSEYJOE
Other than that it will indicate 114 mph down the road. Is this about right?
What?
JERSEYJOE
is that about the correct max?
on a hard pack road, thats not bad. What year Apex?
JERSEYJOE
2006 no engine mods. hard packed road, 8 degrees temp. How accurate is the stock speedo?
That sucker is way off... 12 to 15 MPH, Your should be able to pull 120 on that speedo.2006 no engine mods. hard packed road, 8 degrees temp. How accurate is the stock speedo?
