2011 Apex XTX Secondary Clutch information
owen
I am just wondering if anyone can tell me if all the Yamaha secondary clutches are the same or not. I need a secondary clutch and I found one off a 2008 Nytro and was wondering if there compatible.
Nytro clutch is the oddball with a different spline count. Good news is 1997+ trailing arm sleds use the same splines so there are a lot of spares out there.
I found one near by home and its off a 2001 srx 700 but when I look up the part numbers they are different would it still fit?
yes. running an srx 700 roller clutch on an 04 war and one on my apex shortly.
The older SRX clutch will slide on, but it is not as strong as the Apex clutch. Yamaha has beefed up the area around the buttons, as the clutch would crack in that area previously. So yes, you can run the SRX clutch, but watch your buttons closely.
