dicky2077
anybody now what the stock secondary spring color is on a 05 rx-1 er-le
& what the setting should be?
apltx08
121" = PINK wound 1-6 [70deg] but a little secret use a WHT of a 136" and wind it 3-3 [60deg] you'll gain 1 to 2 sled lenght
Len Todd
Actually, Pink is correct. However, 60 degrees of twist is the correct setting. The mountain sleds with a White Spring were twisted to 70.
I tried a White Spring at 60 and 70 degrees twist. I ended up going back to a pink.
dicky2077
spring
Thanks for the info Guy's
the spring in mine is Black & I can't find any other color's on it & I have it set at 3-3. Not sure if this would make my RPM'S flat line at 9000
apltx08
Here's another thread on secondary set-up...
- 6K
