jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Dalton black orange. Wrapped at 6/2 or 6/3. Guessing 6/3 with your tune and 192 studs that are going to grab. Maybe 6/2 on a straight 35.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Right on. I'm setting up for my 260sm tune. Also going to try my stock spring at 3/3. Both for top speed runs.Dalton black orange. Wrapped at 6/2 or 6/3. Guessing 6/3 with your tune and 192 studs that are going to grab. Maybe 6/2 on a straight 35.
I found a spot an 1hr 35mins away to do some testing. The only problem is outside air temperature is climbing into the 50s fast. Honestly, I've never seen anything like this. I can't catch a break.
Thanks Jon.....
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Trails are great in the UP. We got 20+ the last couple days. -2 this AM. That stock spring is way to soft and the coils are to close. But maybe it will work. But that would not be one I would try.Right on. I'm setting up for my 260sm tune. Also going to try my stock spring at 3/3. Both for top speed runs.
Thanks Jon.....
Doc Harley
- Oct 17, 2016
- Here & there
Well... Thanks for the snow report, by you?!?! Do you not like me or something?!?! Lol.Trails are great in the UP. We got 20+ the last couple days. -2 this AM. That stock spring is way to soft and the coils are to close. But maybe it will work. But that would not be one I would try.
Enjoy the ride......thanks Jon
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No I did rub it in a little.
BUT we just put 143 miles on and the trails are destroyed by 130pm. Which is right now. I’m back and parked! My season is coming to an end after tomorrow as I have to much going on March. Worst season and most trafficked trails I ever seen. No I do like you as you ask a lot of questions and soak it up!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Maybe that will make you feel better about my “report”. Lol
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I think that you shall find that your MS16 2 bar tune likes the 50 degree temps!Right on. I'm setting up for my 260sm tune. Also going to try my stock spring at 3/3. Both for top speed runs.
Thanks Jon.....
I ran both 2 and 3 bar tunes, they are both lean tunes that run much the same at cold or warm temperatures!
I tried both the 6/1 and 6/2 wrap this last week while up country, but I also use stock primary spring!
6/1 is my fav, it allows for a lazy first 1/8 -1/4 throttle but that changes quickly when near 6k revs!
6/2 gives my set up unbelievable throttle response, with every little bit of throttle being very crisp! Gives it that extra grunt down low with just a touch of throttle!
Hard to believe one setting makes such a big difference down low!
Belt deflection settings also change low to mid rpm’s!
Note: Did have my secondary machined .070 years ago to not allow Coil Bind with long stock spring!
Have fun playing with settings and here’s to that 8950-9050 sweet spot!
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, ya did. Lol. At least you got out today.No I did rub it in a little.BUT we just put 143 miles on and the trails are destroyed by 130pm. Which is right now. I’m back and parked! My season is coming to an end after tomorrow as I have to much going on March. Worst season and most trafficked trails I ever seen. No I do like you as you ask a lot of questions and soak it up!
And yes, I try to read first, to see if an old thread pertains to me. Then I'll ask. Also, I'm doing my best to absorb & understand. Im really not looking for the answers handed to me, without the understanding of why.
When it's my turn, I'll pay my good & bad experiences forward. And try my best to help others in my position.
Doc Harley
- Oct 17, 2016
- Here & there
Hmmm.....that's inline with my thoughts. 6/2 grabbing the belt tight and faster reaction.I think that you shall find that your MS16 2 bar tune likes the 50 degree temps!
6/1 taking a little bite out things. Which I thought would help taming the holeshot?!?!
6/2 if you have great traction
6/1 if you do not.
Just my observation....
Thanks, motorhead. Glad you're still riding!!!
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Just got back from a 600mile trip. I will let ya know how my clutch's look. Ran 6/3 this trip. 6/2 my clutch's showed signs of slippage and i glazed a 825 belt in heavyier trail going the trip before. 6/3 had great throttle response, only checked once for heat, running 80/90mph for a long time both were cool. If they are clean when i check them i will be staying at 6/3.
Doc Harley
- Oct 17, 2016
- Here & there
Running thru heavier snow puts a little extra stress on that belt, I bet.Just got back from a 600mile trip. I will let ya know how my clutch's look. Ran 6/3 this trip. 6/2 my clutch's showed signs of slippage and i glazed a 825 belt in heavyier trail going the trip before. 6/3 had great throttle response, only checked once for heat, running 80/90mph for a long time both were cool. If they are clean when i check them i will be staying at 6/3.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I've never had success running the B/O at less than 90 wrap either.
rev them up
- Apr 3, 2006
B/O 6/3, 600 mile trip, speeds were from 30/100mph all trail, new 825 belt, clutches were cool after a good 90mph run.
rev them up
- Apr 3, 2006
This last year pic of the clutches set at 6/2, new 825 belt , 650 miles same driving as above pic. My experience with the 2 wraps yours maybe different.
- 8K
