Elton Buss
Here is the parts fiche
rkkoeb
Yep I think this is the way I have mine setup
RobX-1
- Coldwater, OH
So from left to right (inside the rails) mine is setup as follows:
Adjustment bolt - Washer - Small sleeve - Bogie wheel - Large sleeve - washer - adjustment bolt
Rick
I have my skid out and just double checked and I believe that washer you have listed after the adjustment bolt is incorrect; it should be before the adjustment bolt so the order should be
Washer + Adjustment Bolt + Small Sleeve + Bogie Wheel + Large Sleeve + Adjustment Bolt + Washer
rkkoeb
There are 4 washers total. Two goes on the outside part of the skid and I think two inside
RobX-1
- Coldwater, OH
Correct, I was only focusing on the inside of the rails. The two washers for the outer idler wheels go against the rail and before the small spacer and idler wheel.
I think what makes the microfiche misleading is that it appears to show the washer before the adjustment bolt. However, if you look closely, the line used to show the path of the rear axle bolt does not go through the adjustment bolt bracket which is where the rear axle bolt will go thru the loop on the adjustment bolt. This makes it appear the washer goes before the adjustment bolt bracket/adjustment bolt. When I went out and checked this, not only did I check this on my 08 Apex, but it is this way on my 18 Apex as well.
Here is the order of washers and spacers for the rear axle.
RobX-1
- Coldwater, OH
Using Steiner's picture to help explain this, line #1 would be the driver side rail, line #2 would be the driver side adjustment bolt loop, line #3 would be the passenger side adjustment bolt loop and line #4 would be the passenger side rail.
rkkoeb
so based on this the washer would go up against the adjustment bolt loop
rkkoeb
Adjustment bolt loop - washer - small spacer - bogie wheel - large spacer - washer - adjustment bolt loop
RobX-1
- Coldwater, OH
After posting my edited picture, I noticed I had my lines incorrectly drawn so corrected and updated the post.
gitrdun
It looks like the washers are there on each side of the slide frame to provide a flat surface for the aluminum collars(and adjusters) to butt up against, but your washers were still in the right sections so the spacing was OK, so it must be another reason for your track getting chewed.
rkkoeb
my original rear shaft was bad, had a spun bearing on it, so I picked up a complete used unit. Maybe it is the wrong size? Maybe the small spacer is the wrong size?
Washers go on the skid rails. This prevents the spacers from digging into the rails and allows the adjusters to slide on the rails when adjusting track tension.
rkkoeb
my adjuster sits in a channel so not sure if the washer would fit in this area
