gitrdun
That adjuster needs the washer behind it so that it doesn't eat its way into the slot in the slide frame(skid rail). You don't have damage there, do you?
rkkoeb
no damage. This really will not change the location of the idler no mater what location the washer is in correct?
gitrdun
Shouldn't change the position of the middle wheel, but I would put the washer between the rail and the adjuster, it has a larger diameter than the adjuster, so to protect the rail better. Ask steiner for the measurements of his two aluminum collars between the rails, since he has his apart. Then you can compare to yours. 07 and 09 should be the same collars. I measured the distance from inside the rail to inside the rail at the rear wheels, is 8 11/16 inches. (Measurement was taken at the top of the rail.)
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
am I the only one to pick up on that he said there are no track clips?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I just read the whole thread waiting for someone to say something. I’d worry more about reclipping the track or replace.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Do you have a fully clipped track?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Exactly his rubber problem.
I bolt holding slides on sticking out or rail cap missing?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I had a track clipped every third window, running it on the stand for even a few seconds generated rubber all over the place.
4strokes
- Mar 13, 2018
- charlemont ma
I cant remember how this style suspension works, but have seen many do it yourselfers get a rear scissor up side down and chew things real quick. yet another reason to not remove suspension to do donuts. I honestly don't get the mentality of tossing a suspension in when you have no idea what you are looking at. chewed rubber is a serious sign.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
That is the first thing he needs to address.Exactly his rubber problem.
Seen a Nytro with a blown track last month near Brimley. He had been ridding without clips for awhile, wore thru the rubber then plastic ribs on the track.
