mopar yam
- Nov 10, 2011
Hi guys , just picked up a 2010 vector gt ltx and was wondering what primary spring to use with the 14.5 rollers ? Done this on a nytro before but the vector is a different machine .
radianguy
- Jan 1, 2007
Not sure about the FI Vector, but I'm going to try bl-sl-bl, stock from nytro xtx in my 08 vector.
The primary clutches are set up the same except for spring in the 08 vector LTX GT and 09 Nytro XTX, so I'm thinking this set up should work good in my vector. The FI Vector has different weights, sorry I can't be more help.
mopar yam
- Nov 10, 2011
Ok thanks , anyone else have any suggestions .
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
just wondering what the ,14.5 rollers will do?
radianguy
- Jan 1, 2007
The 14.5mm rollers lower engagement and giver better mid range pull. Essentially acting like a heavier weight. Good improvement over stock clutching for minimal money.
I have them in my Vector, had them in my Nytro but took them out when I installed the ulmer clutch kit, may try them again??
swt20082
- Sep 10, 2014
- 2006 Nytro ER
So are the 14.5mm rollers basically all that the SBM comfort kit does? What spring would accompany them in the kit?
swt20082
- Sep 10, 2014
- 2006 Nytro ER
Yea good question! You're smart!!So are the 14.5mm rollers basically all that the SBM comfort kit does? What spring would accompany them in the kit?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Whats the part number on those rollers?
radianguy
- Jan 1, 2007
8CR-17624-00-00
STAIN
- Feb 29, 2004
- Vermont
- Vermont
thanks...
radianguy
- Jan 1, 2007
No problem!thanks...
Part # for the spring, there are 2 YPY springs.
90501-581L5-00
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Installed the rollers and spring. Lost 400-600 rpm's on shift out. Anyone dialing in a little more secondary wrap to compensate or just taking a gram or two off the weights?
