Shock and track wear
dox06
Jackson, Michigan
17 SW XTX SE
17 G4 Gade 850
OK guys I am not sure if this was covered before on here or not, but took the rear suspension apart today and discovered the bottom of the front shock appears to be ground down. Then I discovered my track has marks (or cuts) in the middle of the track where the bottom of the shock has come in contact with it.
I thought I read something about this issue, but what was the solution to this. Then will my YES warranty do anything about this????? :o| Thoughts and Ideas.
Suspension setting are at stock settings. Only thing I have done is run 114 picks down the middle. None of which line up with the damage......
u sure about the stud line up? It looks to me like the outer edges of the shock are worn more than the middle indicating stud damage. i think the star suspension kit moves the shock up a bit to help this condition. Do a search for star suspensions and check it out. As far as YES goes i think you may be on your own....
