1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Thanks. I did not run it out all the way due to limited distance. It was still pulling strong when I lifted. Man these sleds are a blast!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
What hp and tune?Thanks. I did not run it out all the way due to limited distance. It was still pulling strong when I lifted. Man these sleds are a blast!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Hurricane 300ss header 02module tune.What hp and tune?
22-41 gear
So when the speedo was showing 130mph on the plowed snow covered dirt rd last night with 196 studs in a 1.5 track, how accurate is the sidewinder mph.
My 2019 X-TX LE speedo is consistently out by 7%[over indicating] in comparison to my Garmin GPS. I believe its because Yamacat never calibrated the ECU/Speedo for the X-TX s 3.0 drivers and just used the same calibration for the rest of the 2.86" driver sleds.
When my speedo indicates 128mph the GPS says 119.
I have never held my SW Wide Open long enough to establish a max top speed.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I just ran mine to 120 and another run of 122. Both times my GPS had the exact same speed so they are very close.So when the speedo was showing 130mph on the plowed snow covered dirt rd last night with 196 studs in a 1.5 track, how accurate is the sidewinder mph.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I have a 17 xtx le 137 has the 9 tooth 2.86" drivers from the factory just like the rest of the 137 skids.My 2019 X-TX LE speedo is consistently out by 7%[over indicating] in comparison to my Garmin GPS. I believe its because Yamacat never calibrated the ECU/Speedo for the X-TX s 3.0 drivers and just used the same calibration for the rest of the 2.86" driver sleds.
Agree, my 18 XTX was the same way with the 3.0 pitch.My 2019 X-TX LE speedo is consistently out by 7%[over indicating] in comparison to my Garmin GPS. I believe its because Yamacat never calibrated the ECU/Speedo for the X-TX s 3.0 drivers and just used the same calibration for the rest of the 2.86" driver sleds.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Mine was off 4 mph. Showed 124 but my phone gps said 120So when the speedo was showing 130mph on the plowed snow covered dirt rd last night with 196 studs in a 1.5 track, how accurate is the sidewinder mph.
They were both called 'xtx', but there was major differences like the track and the rear suspension.I have a 17 xtx le 137 has the 9 tooth 2.86" drivers from the factory just like the rest of the 137 skids.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Very jealous, can’t wait to hit a fast trail/ lake so I can do some clutching and unleash my beast again!Hurricane 300ss header 02module tune.
22-41 gear
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
My 17 LTX-LE at 119 speedo was 117 phone gps, and again 126 Speedo was 122. ? GPS. All on snow. Have had a hard time finding ice for the last couple seasons! With more added ponies this season should get a little closer to that 130 mark, and IF I find some ice this year, I shall certainly string it out!Mine was off 4 mph. Showed 124 but my phone gps said 120
Hoping for closer to that 130 Speedo this season.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
3-4 MPH difference is pretty common all the way back to the 2012 procross. My experience compared to GPS.
