moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
Hi guys, I have a big 2 wheel shop dolly that I have been using with great success on my older trailing arm sleds, but can't seem to figure out a good way of using it on my 09 Nytro XTX.
If anyone out there has one, where are you placing the lifting pads to achieve a good balance point and lift it up high enough?
Thanks!
Jeff
Thanks!
Jeff
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
I modified one with two fork that catch the spindle works well!!!
moab11
- Feb 4, 2010
- 2016 SKS 155
Do you happen to have any pics of your modified lift?
yam177
- Aug 14, 2008
- Shoreview MN
Yea next time i go to the trailer I will take some
moab11
- Feb 4, 2010
- 2016 SKS 155
BUMP
Mazz
- Apr 18, 2010
- Esko, MN
- 2008 Fx Nytro RTX 40th
I know what you mean, with all that plastic there is nothing to get a good bite on. I took a measurment between the pads, cut a 2x4 to length, covered it in carpet, and place that on the pads after the lift is rolled under the sled. Not too big of a pain, and now the sled is supported by the frame an not the body panels.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
moab11 said:BUMP
Royal distributing has extension kits for the newer (higher) sled. Maybe check those out see if they might fit. I bought one for mine and if worked good after that.
Here is a link. Double click on the right side page and it will make it bigger so you can see the extension.....
http://www.royaldistributing.com/ma...iew=book&id=14&Itemid=458&firstPageNumber=289
- 6K
