Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
I stretched my 06 Nytro which has the same skid as the 07-08 RTX to a 144 tip-up. I did have the binding problem until I loosened the track to 11/16" free sag. When I studded the track, I went with 2 studs per paddle and left every 3rd paddle un-studded. It is a bit harder to get around corners but not by much
The main reason that I stretched mine to 144 and installed mountain skis was to be able to break trail into camps, etc. If I never went off trail, I would have gone with 136 tip-up
Also, as others have mentioned, extrovert drivers are a must to be able to run the track looser to prevent binding without ratcheting. Depending on your mileage, you might want to consider replacing your drive shaft too
apex55
Good advice on the drive shaft. Stock or after market?
Just passed 10000miles this last weekend.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
You can buy a stock driveshaft with drivers already on from Ulmer Racing.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Never could figure out why they made these things in a 121. They spin and dart like crazy with the short track. Funny thing is all the mfg's are going away from the 121 in favor of 128-129.
apex55
Tracks USA has a 4" extension to stretch to a 128. Would I need to extend the tunnel? I would like a little bigger foot print, but seeing as I ride the twisties I think the 136 is out.
Capt.Storm
Great thread because I'm in the same boat.
Did not know that extroverts should be used with the extensions.
You would have thought with the power this sled has they would have came on the sled to begin with.
chadman
I am stretching my 128 to a 136. I don't think that the 128 is enough.
Apex55, I might stretch my 128 to a 136... if I do so, it will probably be with new rails. So I'll have some 128" available if you choose that length. IMO, the 136" is the best all around length, and probably the best bump version of the Monoshock. Newer versions of the 136" eliminated the cross shaft and special rear arm. If you need parts or even someone to perform the swap, LMK, I'm only about 2.5 hours from you.
apex55
bjowett said:Apex55, I might stretch my 128 to a 136... if I do so, it will probably be with new rails. So I'll have some 128" available if you choose that length. IMO, the 136" is the best all around length, and probably the best bump version of the Monoshock. Newer versions of the 136" eliminated the cross shaft and special rear arm. If you need parts or even someone to perform the swap, LMK, I'm only about 2.5 hours from you.
I'll keep that in mind and thanks for the offer
