WISYAMMI
Picked up a ‘22 Tcat with just over 6k miles.
After removing the exhaust. I spun the turbo by hand expecting it to spin freely. It doesn’t. It this normal?
I expected it to spin a few rotations after letting go.
It’s still under warranty. If it’s not right I’ll taker her in.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Yes it should. Sounds like your turbo is pretty worn.
stgdz
- Mar 27, 2021
- Buffalo MN
Can these turbos be repaired? I've seen turbo repairs before that consist of bearings and a new shaft.
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Spin more by hand, also check for excessive lateral clearance of the rotor shaft . It will free up, turbine side might be a bit coked up, if there isn't any internal damage to the vanes. Inspect both the compressor and turbine vanes for damage.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Mine did this after 1 year. I went for a short spin around my yard early in the year and got a code related to boot pressure.. I took the exhaust off and tried to spin the impeller. It was frozen and I did not force it. Brought it to the selling dealer as it was under warranty. They found the impeller to be "freed up" and drove it for a bit. It never bothered again in 10,000 miles.
Seemed sketchy to me and I checked it every year after with no problems. I chocked it up to being stored in a trailer all summer and condensation playing a role.
Fords4life
- Dec 7, 2021
- South Dakota
I run Hot Shot Secrect Stiction Eliminator since new in both my rurbo sleds for this very reason, keeps turbo oil system clean so no coking happens.
Turboflash
- Mar 18, 2019
- Southern MN
Not sure. A couple years ago I asked a few of the more well-known rebuilders (automotive). I got 2 'no's' and a couple no responses.Can these turbos be repaired? I've seen turbo repairs before that consist of bearings and a new shaft.
Maybe someone has some info?
WISYAMMI
Thanks for the responses. Just to clarify. If I give the impeller a quick half turn spin. It should keep spinning for more than one rotation?
stgdz
- Mar 27, 2021
- Buffalo MN
Any idea of why they said no?Not sure. A couple years ago I asked a few of the more well-known rebuilders (automotive). I got 2 'no's' and a couple no responses.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
They can be repaired.
Turboflash
- Mar 18, 2019
- Southern MN
Where?They can be repaired.
Turboflash
- Mar 18, 2019
- Southern MN
One said they never see IHI turbos needing repair so didn't have parts/experience with them.Any idea of why they said no?
Other said there was no demand because IHI turbos don't fail.
IDK?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Turbo Parts Canada .
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Unless something has changed, these turbos were intended to be replaced in entirety - no service. Not sure if Hurricane Dave has created a rebuild kit.
I had my turbo warrantied after its first year as it made quite a whine - when spooling down - when engine was shut off. No problems since, and that was 11,000km ago.
And yes it should spin freely, not as free as a kids fidget spinner, but certainly a revolution of two.
MS
MS
