TDavidsonVectorGT
Has anyone ever converted/changed over from the Phillips head screws to the D-ring type quick-lock type on an Vector's side panels? Seems like it would make things a lot easier/quicker on the trail (i.e. - belt change)?
Thank you!
Thank you!
the ones in plastic you can do. any of the ones that mount to the frame I do not think you can do. on my apex they are still bolts instead of screws.
I got replacement bolts from the dealer and removed all of the phillip head screws
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Tessie11 said:I got replacement bolts from the dealer and removed all of the phillip head screws
Do you know what the Yamaha part number is?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
TDavidsonVectorGT said:Has anyone ever converted/changed over from the Phillips head screws to the D-ring type quick-lock type on an Vector's side panels? Seems like it would make things a lot easier/quicker on the trail (i.e. - belt change)?
Thank you!
I did the same as Tessie, but you don't need to remove the bottom panel in order to change the belt.
The Hex head bolts I got I believe were for a Phazer? Sorry, no part numbers but I do have a post somewhere (last year?) about it.
