Side panel wind flare install???
tnc110
Sidewinder BTX SE, SRXs
I cut out the paper template (what a joke!) but the template holes do not line up with the holes in the flares. Any advice? I guess I need to make my own templates.
I really wish the leading edge of the flares had more contact area, that way I could install with double sided tape, but I dont think 1/8" will cut it.
does it go around a curved body panel is that why the template don't line up when flat? Just a thought never worked with them before.
It does go around the cuve, but the hole to hole distance on the same surface is not the same.
Nice sorry for your luck with that one
Sent from my XT1564 using Tapatalk
ended up installing with 3M double sided moulding tape. Seems to be pretty strong. Time will tell. Wasn't too excited about drilling holes in my panels anyway....
I hope it holds for you post up your results latter in the year so others can benefit most hate drilling holes in panels.
Went out in 4*f...3m did not hold. What is usually rubbery gooey tape, turned brittle in the cold. They are screwed on now. It was a pain in the button to get holes where they needed to be.
Thanks for the game update
