jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What is the fuel level at when your having this issue? Does it do it full? Or is happening when it’s below quarter. I still think when these winders get low something is happening? Fuel sloshing around and fuel pump sucks air intermittently?Perfect, glad to hear that I am not alone in this battle, I getting a replacement pump tomorrow.
alain langlois
- Feb 7, 2020
- Quebec
- sidewinder ltx dx 2018
The tank was mid range.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay. Thanks.The tank was mid range.
alain langlois
- Feb 7, 2020
- Quebec
The problem was solved by replacing the fuel pump. The new pump showed a good and solid pressure at idle when compaired to the faulty pump.
Drove the sleed for 500 km and no problem at all. very good acceleration, no power roolback. Sleed run just like before. did not replace the pressure regulator.
Very happy, thanks guys for your comment.
Al.
Al.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Glad you got it sorted out.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Good news. I swear mine has exact symptoms you describe but only with 3 gallons or less in the fuel tank. Thought I had fuel octane issues at times. It’s the fuel sloshing all the way to back of tank on. Hard pulls under 3 gallons of gas. We purposely replicated miles after fill ups and it does it every time. Throws my knock light also. 117 mph today and it flashed. Was going down a steep hill flattened out on turn and just got into gas slightly and it falls on its face ever so slightly. All of this stuff at 3 gallons or less in tank.
Another Phase
That's great news Alain. Happy to hear you had success!
SRX Boy
I had the same issue with my 2017 Sidewinder after 15,000kms. Replace the pump and we are back in business. Not cheap!!!
Turboflash
- Mar 18, 2019
- Southern MN
Cheap pumps made in China!The problem was solved by replacing the fuel pump. The new pump showed a good and solid pressure at idle when compaired to the faulty pump.
Al.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
How much is a stock replacement pump?I had the same issue with my 2017 Sidewinder after 15,000kms. Replace the pump and we are back in business. Not cheap!!!
alain langlois
- Feb 7, 2020
- Quebec
If I recall at the dealer the pump was 560 plus taxe, I paid 150 used.How much is a stock replacement pump?
I was surprised the pump was made in USA not china.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I don’t think the stock pump is BAD. It’s just not capable with any kind of tune when your tank gets low on fuel. IMO
DMCTurbo
- Nov 12, 2005
Geeze I'd buy TDs upgraded fuel pump for $199 CDN if mine craps out.If I recall at the dealer the pump was 560 plus taxe, I paid 150 used.
