Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
My buddy lost his carbide and ended up wearing down the keel of the ski. Would sidewinder skis fit his 2011 Apex? He found some for sale on kijiji. Thanks
they are about 1/2" taller at the mount than the apex ski is like the curve xs ski. you would need to add a spacer under the stock rubbers to make them work correctly. i used a peice of rubber when i run my curve xs skis.
the older rx/apex skis will work on it as well with a 1/8-1/4" shim between the ski and the rubber. i run 09 mtx skis on both my xtx's set up this way.
where are you looking for this ski?
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Most hits for skis are in Winnipeg area. 2 hours from us. Sidewinder skis are in Dryden, ON. 1.5 hours away
ok. if you where closer i have the tuners i took of my 16 apex xtx but that will be too long for you guys most likely.
1/2 hour each way is not bad for the correct ski. Just sayin'Most hits for skis are in Winnipeg area. 2 hours from us. Sidewinder skis are in Dryden, ON. 1.5 hours away
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I have a set of brand new apex skis off an 08 that I took off too put on C& A I live in Fort Frances Ont
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Cool. I will let him know. Do you know if they fit without modification? Any carbides with those? Thanks
they will fit. just need to add 1/8" shim between the spindle rubber and the ski at the rear of the pocket.
