poor farmer/logger
- Dec 3, 2012
- Saskatchewan
- 2015 SR Viper XTX 2009 Yamaha Nytro XTX
I’ve been strongly considering it as well but haven’t seen many reports of guys using them yet. I have the combination saddle bag/rear bag on mine so I can’t put a linq tank on it. Already tried to put one in the bag and it didn’t fit. I used to be able to do 180-200 kms comfortably on my viper with the stock tank but now I’m down to 150-170 kms. If I’m in deeper snow that cuts back to 120 kms pretty quick. Power is fun but she’s sure thirsty lol. Did 180 kms one day and ran out 1 mile from the truck when I got on the throttle pretty hard. Gas ran to the back of the tank and couldn’t pick it up. I put 33 lts in when I got home. That’s what’s left me with a little bit of uneasy feeling traveling further without extra gas.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
It sucks to start looking for gas as soon as you fill up.uneasy feeling traveling further without extra gas.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
They seem a little ugly though....
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I agree! Always hated the though of dragging around an ugly red can on the back. I'm considering it. Just need an alternative bag then.Will do.
I feel just having the 12 gallon tank will be easier.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I just pack a siphon and when I hit a bar I fill up! Just joking
hellflyer
- Dec 2, 2008
Great idea! LolI just pack a siphon and when I hit a bar I fill up! Just joking
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
My biggest concern with putting a extra tank on the back is bending my tunnel. I don’t carry much for weight in my rear bag just for that reason. The trail tank at least the weight stays where it’s meant to. Just wish it had. Little bit more capacity then it does. It’s not a huge gain if everyone is putting 37-38 lts in the tank as they sit. Trail tank is 44 lts I think. Wouldn’t hurt if the price was 100-150 cheaper too lol.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I know a few guys with 137's and they carry the 15l linq and have never had an issue. Keep it filled all the time and they drive pretty hard.
I mirror your concern for bending the tunnel but it seems to hold up.
MS
MS
RAMSOMAIR
Been doing it for 7 years on 2 different SW’s and no issues
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Trail tank is installed. Fit seems really good.
I am just waiting for my ATACH brackets and bag and I will post some photos.
I went with the CAT system instead of the Kimpex one as I figured it would be supported longer.
Arc21981
- Jan 31, 2019
- Portland,Maine
- 2018 Sidewinder xtx se 137"
I ran one last year, it worked good and was nice having a little extra. The only thing I had issue with was where the sending unit goes. It started to leak and was a royal pain to get in. I ended up sanding hole a little bigger and sanding the top flat so it would tighten down better.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
From the little research I've done, the trail tank is a flawless fit and will go unnoticed by most. The look is factory.
I've carefully considered it, but I'm always able to make it to the next station. So for $500us, I'm just not quite there.
My sled gets 15mpg, if I was closer to 10mpg, it would be done.
Last year with the tune I was able to avg 13.8mpg and that's only cuz I couldn't keep my thumb off the flipper.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The only fitment issue was the foam pads they put on the tank to protect it from rubbing on the down tubes that go towards the rear. The location of the pads wouldn't allow the seat to clip onto those tubes. I relocated them a little further forward.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Had this setup on 3 procross's. Lower/more centralized center of gravity and lets you run a full tunnel pack. Does not interfere with riding whatsoever. A bit of fabrication though. These particular tanks are NLA but knockoffs or rotopax would work. these were 1.5 gal each filled completely, rated for 1.3
